Введение
This RAM replacement guide can be used to replace the RAM after damage or repeated use. The RAM can be replaced to compensate for diminished performance, crashing, video card loading failure, corrupted data files, and incorrect system RAM display.
Выберете то, что вам нужно
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Gently remove the RAM by pulling up the metal release brackets, pushing the RAM forward out of its port, and lifting it up and out.
