Введение
Removal of the back panel is crucial for repairing the hardware in the computer or the back panel itself due to dents/other damages. This guide will walk you through the process of how to remove and/or replace the back panel of your device.
Выберете то, что вам нужно
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the 10 screws (6mm) around the border of the panel.
Using the Torx T5 Screwdriver, remove the screws.
Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
Еще один человек закончил это руководство.
