Введение
If your speakers no longer work correctly, this guide will teach you how to remove the laptop's speaker.
Выберете то, что вам нужно
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the 10 screws (6mm) around the border of the panel.
Using the Torx T5 Screwdriver, remove the screws.
Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
Remove 2 screws (2mm) from each of the speakers, 4 screws total, using the PH #000 screwdriver.
After the cables are disconnected, remove the speakers by lifting the speakers up.
Еще один человек закончил это руководство.
