Введение
The Lenovo Ideatab A1107 Front Camera Replacement guide will show users how to safely remove the front camera component from the Lenovo Ideatab A1107. Included in the guide are the proper tools needed to complete the replacement, as well as photos with mark-ups.
Выберете то, что вам нужно
Insert a plastic opener in-between the black back panel and the silver body of the tablet.
Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
Wedge a plastic opening tool in between the battery and the internal components of the device.
Use the plastic opener tool to remove the battery from its casing.
Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
Locate the black electrical tape strip on the side of the device.
Gently remove the tape from the device using the tweezers.
After removing the electric tape, gently lift up the green control panel.
Taking the tweezers, remove the ribbon cable from the control panel.
Once the ribbon cable is removed from the panel, the display should separate with ease.
Еще один человек закончил это руководство.
