Lenovo Legion Y520-15IKBN Battery Replacement
Выберете то, что вам нужно
  1. Lenovo Legion Y520-15IKBN Battery  Replacement, Base Panel: шаг 1, изображение 1 из 1
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Battery  Replacement: шаг 2, изображение 1 из 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Battery  Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  4. Lenovo Legion Y520-15IKBN Battery  Replacement: шаг 4, изображение 1 из 2 Lenovo Legion Y520-15IKBN Battery  Replacement: шаг 4, изображение 2 из 2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  5. Lenovo Legion Y520-15IKBN Battery  Replacement: шаг 5, изображение 1 из 1
    • Lift the battery up and out of the chassis.
Заключение
11 участников успешно повторили данное руководство.
Naomi Williams
Участник с: 10/04/18
771 Репутация
Автор 2 руководств
Команда
Linn Benton Community College, Team S1-G2, Karnes Fall 2018 Участник Linn Benton Community College, Team S1-G2, Karnes Fall 2018
LBCC-KARNES-F18S1G2
4 членов
Автор 13 руководств
3 Комментариев
Thank you, very helpful.
ska Smith - Ответить
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Ricardo Peixoto - Ответить
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 73
За последние 30 дней: 351
За всё время: 20,164
