Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your laptop will not start up or stay charged you may need to replace the battery. To follow this guide you only need a plastic opening tool such as a spudger or credit card and a Phillips #00 screwdriver. It is not a difficult project and the hardest part will be prying the back piece off.
Выберете то, что вам нужно
Remove thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
The bottom piece will make popping noises as it is pulled from the laptop.
The battery is a long black rectangle located near the bottom of the device.
Use a Phillips #00 screwdriver to unscrew the four 4.0 mm screws holding the battery in place.
There is a small bundle of wires held together with black tape located on the top edge of the battery. Unplug it completely.
11 участников успешно повторили данное руководство.
3 Комментариев
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
