Введение
Replacing faulty fans is essential to keeping your computer’s insides working. This guide details how to remove the fans to either clean or replace them to ensure the processor does not overheat.
Инструменты
Запчасти
Детали не указаны.
Use a Phillips screwdriver to remove the eleven screws securing the back cover:
Five 7 mm screws
Six 4 mm screws
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
2 участников успешно повторили данное руководство.
Комментариев: 2
Thank you! Very clear and well photographed :)
Any recommended stores for the replacement fans?
