Введение
Replacing faulty fans is essential to keeping your computer’s insides working. This guide details how to remove the fans to either clean or replace them to ensure the processor does not overheat.
Выберете то, что вам нужно
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
Lift the fans out of their positions and remove them from the device.
Don't forget to pick up thermal paste so you get a good contact between the CPU and GPU and the heat sinks!
6 участников успешно повторили данное руководство.
4 Комментариев
Thank you! Very clear and well photographed :)
Any recommended stores for the replacement fans?
Worked like a charm, thank you!!
where can i get a good replacement please
