Введение
The motherboard acts as the central hub of communication between all of the components in your device. If random applications are quitting or if you’re seeing the “blue screen of death” (BSoD), it may be time to replace the motherboard in your computer. This guide will go through the steps on how to replace the motherboard of the Lenovo Legion Y530-15ICH.
Инструменты
Запчасти
Детали не указаны.
Use a Phillips screwdriver to remove the eleven screws securing the back cover:
Five 7 mm screws
Six 4 mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
Remove the plastic covering after the screws have been loosened.
Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
Remove three 4mm screws using a JIS #1 screwdriver.
Remove the black cover the screws were holding down.
Remove the 4mm screw on top of the audio driver using a JIS #1 screwdriver.
Pull the audio cables gently off the audio driver.
Remove the audio driver from the motherboard.
Remove twelve 4mm screws circled in red using a JIS #1 screwdriver.
Peel off the Lenovo sticker and remove one 4mm screw with a JIS #1 screwdriver.
Remove two ribbon cables in the circled areas. Gently pull them out of their ports.
2 участников успешно повторили данное руководство.
Комментариев: 2
Kaylie Klausing
I hope you burn in !&&*
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
