Введение
The random access memory (RAM) module in your device acts as the temporary storage units while the computer is running. The RAM allows the computer to access and load applications faster as well as the operating system. If your computer is acting slow if your applications won’t load, you may need to replace the RAM.
This guide will help users to upgrade their RAM in their Lenovo Legion-15ICH. Replacing the RAM is recommended if the device is running slower than usual.
Выберете то, что вам нужно
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Use the plastic opening tool to unlatch the metal cover that secures the RAM housing.
Push the metal tabs inwards to release the RAM.
After the clips are removed, the RAM will push up at an angle.
Remove the RAM from the device.
4 участников успешно повторили данное руководство.
