Инструменты
Запчасти
Детали не указаны.
Этот шаг не переведен. Помогите перевести
Remove the five 7 mm screws using a Phillips #0 screwdriver.
Remove the six 4 mm screws using a Phillips #0 screwdriver.
Slowly and carefully pry off the backside of the computer using an opening pick.
Detach the two antenna wires attached to the wireless LAN card.
Remove the single 4 mm screw using a Phillips #0 screwdriver.
Remove the wireless LAN card.
Insert the new wireless LAN card.
Re-insert the 4 mm screw using Phillips #0 screwdriver.
Re-attach the black antenna cable to the top pin on the wireless LAN card.
Re-attach the white antenna cable to the bottom pin on the wireless LAN card.
Snap the back cover onto the laptop.
Using a Phillips #0 screwdriver, re-insert the five 7mm screws.
Using a Phillips #0 screwdriver, re-insert the six 4mm screws.
Еще один человек закончил это руководство.
