Введение
This guide goes over the steps to remove the front camera from the tablet.
Выберете то, что вам нужно
Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
Locate the LCD cable connector and gently pry it directly up with a spudger.
Remove the 5 ribbon cables. use the tip of the spudger to flip up the retaining flap, making sure to lift on the hinge and not the connector itself, then remove the cable from the connector.
Remove the red and black cable using the tweezers by gently pulling the connector to the right.
3 участников успешно повторили данное руководство.
