ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Π²Π΅Π΄Π΅Π½ΠΈΠ΅
Once the keyboard and touch pad have been removed, the battery can be easily replaced by removing three screws and a connection cable.
Запчасти
  1. Power down the Chromebook before starting any repair. Opening up your Chromebook voids the manufacturer warranty.
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Use a plastic opening tool to pry off the four rubber pegs from the bottom housing. Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles. Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Flip the laptop over and open the screen. Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool. Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket. Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket. Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket. Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a  small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Remove the keyboard and trackpad panel away from the device.
    • Remove the keyboard and trackpad panel away from the device.
  8. Disconnect the white charging cable connectors by pulling straight down on the connector. Disconnect the white charging cable connectors by pulling straight down on the connector. Disconnect the white charging cable connectors by pulling straight down on the connector.
    • Disconnect the white charging cable connectors by pulling straight down on the connector.
  9. Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery. Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
    • Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
  10. Peel up on the silver cable enough to  remove the adhesive to the battery.
    • Peel up on the silver cable enough to remove the adhesive to the battery.
    • When moving the adhesive cable, be careful not to disconnect or damage the cable and motherboard.
  11. Remove the battery by pulling back and up.
    • Remove the battery by pulling back and up.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
6 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Jacob Taylor
Участник с: 26.04.2017
242 РСпутация
1 руководство Π°Π²Ρ‚ΠΎΡ€Π°
Команда
Cal Poly, Team S21-G2, Livingston Spring 2017 Участник Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
4 Ρ‡Π»Π΅Π½ΠΎΠ²
Автор 12 руководств
Один ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 2
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 12
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 46
Π—Π° всё врСмя: 7,706
