Введение
In the case where your Lenovo N21's screen is cracked, malfunctioning, or not working at all, you may need to replace the screen. This can be done easily by removing the protective panel around the screen and removing a few screws. Be careful when pulling away the screen's protective panel, because bending it too far may cause it to snap.
Выберете то, что вам нужно
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
Flip the laptop over and open the screen.
Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
Carefully pry off the six small rubber pads around the screen with a plastic opening tool to expose the screws.
Remove the six 4.0mm Phillips screws that are underneath the rubber pads with a screwdriver.
Use a plastic opening tool to carefully pry the thin plastic frame away from the screen.
Remove the four 3.0mm Phillips screws symmetrically placed on either side of the screen.
Pull the cable connecting the motherboard to the screen straight out from the back of the screen.
5 участников успешно повторили данное руководство.
