Lenovo N22 Chromebook Individual Key Replacement
Выберете то, что вам нужно
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: шаг 1, изображение 1 из 1
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: шаг 2, изображение 1 из 2 Lenovo N22 Chromebook Individual Key Replacement: шаг 2, изображение 2 из 2
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
Заключение
13 участников успешно повторили данное руководство.
Jackson Tucker
Участник с: 04/26/17
863 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S21-G1, Livingston Spring 2017 Участник Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 членов
Автор 14 руководств
6 Комментариев
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - Ответить
Where can I order individual keys?
Mallory Montreuil - Ответить
He tried to turn it on but it did not work
Clayton Sensing - Ответить
I took it off and now it broken he he
BRENNEN FIRKUS - Ответить
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 22
За последние 30 дней: 104
За всё время: 13,618
