Lenovo N22 Chromebook Speakers Replacement
Выберете то, что вам нужно
  1. Lenovo N22 Chromebook Speakers Replacement, Keyboard: шаг 1, изображение 1 из 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: шаг 1, изображение 2 из 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: шаг 1, изображение 3 из 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Speakers Replacement: шаг 2, изображение 1 из 3 Lenovo N22 Chromebook Speakers Replacement: шаг 2, изображение 2 из 3 Lenovo N22 Chromebook Speakers Replacement: шаг 2, изображение 3 из 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Speakers Replacement: шаг 3, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 3, изображение 2 из 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Speakers Replacement: шаг 4, изображение 1 из 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Speakers Replacement, Battery: шаг 5, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement, Battery: шаг 5, изображение 2 из 2
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Speakers Replacement: шаг 6, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 6, изображение 2 из 2
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Speakers Replacement: шаг 7, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 7, изображение 2 из 2
    • Lift up on the tabs that were held down by the screws to remove the battery.
  8. Lenovo N22 Chromebook Speakers Replacement, Speakers: шаг 8, изображение 1 из 1
    • Use the edge of the opening tool to separate the speaker cable connector from the black socket on the motherboard.
    • Pull the cables towards you and away from the socket.
  9. Lenovo N22 Chromebook Speakers Replacement: шаг 9, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 9, изображение 2 из 2
    • Use the pointed end of the spudger to pop the speaker up and off of the two posts.
  10. Lenovo N22 Chromebook Speakers Replacement: шаг 10, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 10, изображение 2 из 2
    • Slide the wire that connects the two separate speakers out from under the guide tabs.
  11. Lenovo N22 Chromebook Speakers Replacement: шаг 11, изображение 1 из 2 Lenovo N22 Chromebook Speakers Replacement: шаг 11, изображение 2 из 2
    • Use the flat end of the spudger to pop the speaker up and off of the two posts.
Заключение
Kevin Yerina
Участник с: 04/26/17
414 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S21-G1, Livingston Spring 2017 Участник Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 696
