Введение
The Lenovo S20-30 netbook's battery life is decent, but will not last forever. It is common for the battery to need to be replaced after so many years. If your screen is unresponsive it may be due to a faulty battery. It is simple to replace the battery, so when your's does go out you can easily replace it. Battery parts range from $30-$100 depending on the kind you need. Here are the steps to replacing the battery in the Lenovo S20-30 netbook. No tools are required for this replacement.
Выберете то, что вам нужно
Slide the manual battery latch to the unlock position, so that the red is showing.
Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
Grab new Lenovo S20-30 battery for replacement.
Еще один человек закончил это руководство.
