Введение
Use this guide to remove the USB 2.0 Power Assembly for replacement.
Выберете то, что вам нужно
Flip the unit over so the bottom is facing you.
Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
Use the iFixit Opening Tool to flip up the grey locking flap on the ZIF (zero insertion force) connector to allow removal of the ribbon cable.
Remove the large ribbon wire using any pair of ESD safe tweezers.
Pull up on the large circuit board and slide it through the opening with the ribbon cable attached to it.
