Введение
This guide will demonstrate in detail the process of replacing the tablets camera.
Выберете то, что вам нужно
Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
Separate the battery from the case.
Use a plastic opening tool or a tweezer to remove any tape.
Unplug the electrical connectors by lifting the clip that hold them in place.
Use a plastic opening tool or tweezers to remove the twisted pairs that are held in place by retaining tabs.
Gently lift up the motherboard starting from the right side. The final strip can be removed by gently pulling it up from the case.
Remove the motherboard completely from the back panel.
Use the plastic opening tool to lift up the camera lens starting from the left side between the gap.
Remove the metal tape that connects the camera lens to the panel in order to remove the camera lens.
