Введение
This guide will show you how to safely remove the battery component of your tablet.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
Working your way around the edge of the battery, pry out the battery using a plastic opening tool
5 участников успешно повторили данное руководство.
2 Комментариев
I fixit might have a replacement battery
