Lenovo Tab 2 A8 Front-Facing Camera Replacement
Выберете то, что вам нужно
  1. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: шаг 1, изображение 1 из 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: шаг 1, изображение 2 из 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: шаг 1, изображение 3 из 3
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Front-Facing Camera Replacement: шаг 2, изображение 1 из 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: шаг 2, изображение 2 из 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Front-Facing Camera: шаг 3, изображение 1 из 1
    • Using tweezers, peel off the anti-static sticker from the camera connection port.
  4. Lenovo Tab 2 A8 Front-Facing Camera Replacement: шаг 4, изображение 1 из 1
    • Lift the camera out of its socket in the motherboard. Then, using tweezers to grasp the camera connector, carefully pull the connector horizontally out of the port.
    • Be aware that the camera connector will be firmly lodged in the port. When successfully removed, the top side of the port pops up.
  5. Lenovo Tab 2 A8 Front-Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Using tweezers to grasp the camera connector, lift the camera out of its socket.
Заключение
3 участников успешно повторили данное руководство.
Tim Gales
Участник с: 10/06/15
478 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 2-4, Plummer Fall 2015 Участник Eastern Washington University, Team 2-4, Plummer Fall 2015
EWU-PLUMMER-F15S2G4
4 членов
Автор 13 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,017
