Введение
This guide illustrates the procedure to remove the rear-facing camera of your device.
Выберете то, что вам нужно
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Using a spudger, pry upward on the camera connector to free it from the motherboard.
Use tweezers to grasp the camera connector and lift the camera out of its socket.
4 участников успешно повторили данное руководство.
