Выберете то, что вам нужно
Start at the microSD slot.
Use the opening pick to slide underneath the back cover of the tablet.
Slide the opening pick around the tablet until the back cover is off.
Remove the 8 screws with a Phillips #000 screwdriver [bit].
There is a screw under the blue "s" sticker.
Remove tape holding plate down.
Use precision tweezers or your fingers to remove plate.
Remove yellow tape.
Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
Once the tabs are off, lift the battery up from the frame.
Remove 16 screws from the midframe with Phillips #000 screwdriver [bit].
Using an opening pick, find a spot to lift the bracket around the tablet.
When the opening pick is inserted between the bracket and tablet, move the pick around the whole tablet to completely detach the bracket.
Desolder the blue and red wires from the motherboard.
Once wires are detached, use a metal spudger tool to lift the vibrator.
