Введение
If you have to forcefully press the power button multiple times to get your screen to come on, follow these simple steps to replace the power button.
Выберете то, что вам нужно
Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
Gently lift the clear-yellow rubber flap from the plastic pegs with a plastic opening tool.
