Lenovo Tab S8 Speakers Replacement
Выберете то, что вам нужно
  1. Lenovo Tab S8 Speakers Replacement, Battery: шаг 1, изображение 1 из 2 Lenovo Tab S8 Speakers Replacement, Battery: шаг 1, изображение 2 из 2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Speakers Replacement: шаг 2, изображение 1 из 3 Lenovo Tab S8 Speakers Replacement: шаг 2, изображение 2 из 3 Lenovo Tab S8 Speakers Replacement: шаг 2, изображение 3 из 3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Speakers Replacement: шаг 3, изображение 1 из 3 Lenovo Tab S8 Speakers Replacement: шаг 3, изображение 2 из 3 Lenovo Tab S8 Speakers Replacement: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
  4. Lenovo Tab S8 Speakers Replacement, Motherboard: шаг 4, изображение 1 из 2 Lenovo Tab S8 Speakers Replacement, Motherboard: шаг 4, изображение 2 из 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
  5. Lenovo Tab S8 Speakers Replacement: шаг 5, изображение 1 из 2 Lenovo Tab S8 Speakers Replacement: шаг 5, изображение 2 из 2
    • Remove the press-fit cable located next to the camera by using opening tool to gently pry it up.
    • Unlock the ZIF connector by lifting the black bar and sliding the ribbon cable out.
  6. Lenovo Tab S8 Speakers Replacement: шаг 6, изображение 1 из 3 Lenovo Tab S8 Speakers Replacement: шаг 6, изображение 2 из 3 Lenovo Tab S8 Speakers Replacement: шаг 6, изображение 3 из 3
    • Remove the five M1.6 x 2 mm screws from the motherboard with the JIS J000 screwdriver.
    • There is one screw hidden under a circular white sticker directly below the camera. Remove the sticker to take out the screw that is underneath it.
    • Cut or remove the piece of silver tape from the motherboard.
  7. Lenovo Tab S8 Speakers Replacement: шаг 7, изображение 1 из 3 Lenovo Tab S8 Speakers Replacement: шаг 7, изображение 2 из 3 Lenovo Tab S8 Speakers Replacement: шаг 7, изображение 3 из 3
    • Use the spudger to gently pry the motherboard out of the frame from each side.
  8. Lenovo Tab S8 Speakers Replacement, Speakers: шаг 8, изображение 1 из 3 Lenovo Tab S8 Speakers Replacement, Speakers: шаг 8, изображение 2 из 3 Lenovo Tab S8 Speakers Replacement, Speakers: шаг 8, изображение 3 из 3
    • Once you have removed the motherboard and the battery, locate both the upper and lower speakers.
    • The lower speaker wire is glued to the back casing of the device, so be gentle when removing the wire.
    • Lift up the wire with a plastic opening tool. Make sure this tool has a sharp edge.
Заключение
Thomas Rill
Участник с: 08/26/15
338 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 3-6, Eyestone Fall 2015 Участник USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 11
За всё время: 1,115
