Введение
Is your battery power draining fast, or won’t charge, having issues and making certain time? If so its time to replace the battery on your laptop. Replacing your battery will make sure your device is running at an optimum level and will keep you from recharging more frequent than usual or from not being able to use it at all.
Power down your laptop and disconnect from any external power sources before beginning this guide.
Выберете то, что вам нужно
Using both hands, push out the two buttons beneath the outer edges of the battery compartment.
To reassemble your device, use the new replacement battery and follow these instructions in reverse order.
Еще один человек закончил это руководство.
