Введение
Does your Lenovo ThinkPad E570 laptop have a “no good device” error message, run excessively slow, have active apps often freeze/crash, or does the drive become read-only? If so, it is time to replace the solid state drive (SSD). Making sure your SSD is up-to-date and working fine will enhance your device’s ability to run apps and make sure optimum running speed is used.
Power down your laptop and disconnect from any external power sources before beginning this guide.
Выберете то, что вам нужно
Turn the laptop over so that the bottom is facing upwards.
Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
Carefully remove the back panel.
Remove the single 5 mm screw using a Phillips #00 screwdriver.
Lift off the SSD carefully.
Еще один человек закончил это руководство.
