Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
Swing the cover out slightly like a hinge.
Pull the cover directly away from the case towards the base of the laptop.
Lift the cover up and away from the device to remove it.
To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
Slide the old hard drive directly out.
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
Wedge the plastic opening tool between the upper and lower halves of the lower case.
Lift the end of the opening tool slowly until the case separates.
Locate and disconnect the 4 ribbon wires from the top case.
Locate and disconnect the two additional connecting wires.
Remove the two M2 x 3mm securing the the optical drive to the device using a Phillips #000 screwdriver.
Unscrew the two M2 x 3mm screws near the hinges using a Phillips #00 screwdriver.
Slide the black and grey wires out from underneath the plastic tab with the plastic opening tool.
Disconnect the black and grey wires connecting the screen and the motherboard.
Pull out the fabric covered wire connecting the Screen to the motherboard underneath the cooling fan.
Use a Phillips #0 screwdriver to remove the four M2 x 6mm screws connecting the heatsink to the motherboard.
Disconnect the cable connecting the fan to the motherboard, then remove the fan and the attached fan component from the case.
Use a Phillips #000 screwdriver to remove three M2 x 2mm screws from the sides of the motherboard.
Disconnect the cable connecting the VGA connector to the motherboard. Then disconnect the cable connecting the card reader to the motherboard.
Lift the motherboard from the case and detach the cable from the back of the motherboard connecting to the DC power jack. Remove the motherboard from the case.
