Введение
This guide will assist you in replacement of the Lenovo Thinkpad Edge E520 keyboard. You will require a Phillips head screwdriver for this replacement.
Выберете то, что вам нужно
Unscrew the two 3.175 mm diameter and 6.35 mm length screws with keyboard symbols pointing at them using a Phillips head screwdriver.
Turn the laptop back over so that the keyboard is facing you.
Use your hands to separate the keyboard from the laptop
3 участников успешно повторили данное руководство.
