Введение
This guide will tell you how to replace the RAM in your Lenovo Thinkpad Edge E520.
Выберете то, что вам нужно
Flip the computer so that the back is facing upwards.
Locate the switch used to release the battery.
Slide the switch towards the unlocked lock icon.
While holding it in the unlocked position, slide the battery towards the hinge.
Fully separate the battery pack from the back of the laptop.
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Locate the two thin metal tracks that hold each RAM in place.
Using light pressure, press the tracks outward and the RAM should pop up.
A light pull on the RAM should remove it with no issues.
Repeat from the second step to the third step to remove the second chip.
Еще один человек закончил это руководство.
