Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Lenovo ThinkPad Edge E530, E530c - how to replace / upgrade the Processor.
_________________________________________________
Видео обзор
  1. Switch-off the Laptop and remove the battery. The HDD/Memory Cover is held by 3x Phillips screws. Remove them. Remove the Cover.
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Disconnect the Fan cable. Remove the 2x screws from the Fan module. Unscrew 4x screws around the processor.
    • Disconnect the Fan cable.
    • Remove the 2x screws from the Fan module.
    • Unscrew 4x screws around the processor.
    • Carefully lift the Cooling System.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound. If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off. Separate the Fan from the Heat-sink.
    • Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Separate the Fan from the Heat-sink.
  5. Use a soft anti static brush and clean the Heat-sink on the inside.
    • Use a soft anti static brush and clean the Heat-sink on the inside.
    • Before installing a new Cooling System or reinstalling the old one, you must clean the processor from the old thermal compound and put a new one.
  6. Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound. If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off. To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
    • Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
    • To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
    • Lift the Processor from the socket.
    • Be careful to lift straight up without bending the CPU pins.
  7. Before you place the new Processor, be sure the socket screw is in the open position. Delicately place the Processor into the socket.
    • Before you place the new Processor, be sure the socket screw is in the open position.
    • Delicately place the Processor into the socket.
    • Close the socket with the socket screw.
    • Put thermal compound on the processor surface and carefully install back the Cooling system.
Заключение
2 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
172 616 Репутация
Автор 307 руководств
Команда
Master Techs Участник Master Techs
Community
294 членов
Автор 943 руководств
Один комментарий
Bonjour, peut-on remplacer le CPU par n'importe quel autre plus puissant, ou y a-t-il des restrictions ?
francoislaurent - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 74
За всё время: 4,914
