Введение
Lenovo ThinkPad Edge E530, E530c - how to replace / upgrade the Processor.
_________________________________________________
Выберете то, что вам нужно
Видео обзор
Switch-off the Laptop and remove the battery.
The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
Remove the Cover.
Disconnect the Fan cable.
Remove the 2x screws from the Fan module.
Unscrew 4x screws around the processor.
Carefully lift the Cooling System.
Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
Separate the Fan from the Heat-sink.
Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
Lift the Processor from the socket.
Close the socket with the socket screw.
Put thermal compound on the processor surface and carefully install back the Cooling system.
3 участников успешно повторили данное руководство.
2 Комментариев
Bonjour, peut-on remplacer le CPU par n'importe quel autre plus puissant, ou y a-t-il des restrictions ?
