Введение
Lenovo ThinkPad Edge E530, E530c - how to replace / upgrade the Processor.
_________________________________________________
Выберете то, что вам нужно
Видео обзор
Switch-off the Laptop and remove the battery.
The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
Remove the Cover.
Disconnect the Fan cable.
Remove the 2x screws from the Fan module.
Unscrew 4x screws around the processor.
Carefully lift the Cooling System.
Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
Separate the Fan from the Heat-sink.
Clean the old thermal compound. Use a lint-free cloth and isopropyl alcohol to clean the old thermal compound.
To remove the Processor, turn the CPU socket screw 90 degrees to open the socket.
Lift the Processor from the socket.
Socket screw must be turned 180 degrees to the left until the tab on the screw reaches the stop tab on the socket. At this point the CPU will lift easily out. Carefully place new CPU on socket so little gold arrow on the corner of the chip is oriented to face corner on socket with missing pin hole. CPU should drop easily into place. With CPU in place turn set screw 180 degrees to the right until screw tab meets stop tab on socket.
Close the socket with the socket screw.
Put thermal compound on the processor surface and carefully install back the Cooling system.
3 участников успешно повторили данное руководство.
2 Комментариев
Bonjour, peut-on remplacer le CPU par n'importe quel autre plus puissant, ou y a-t-il des restrictions ?
