Lenovo ThinkPad Helix Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: шаг 1, изображение 1 из 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: шаг 2, изображение 1 из 3 Lenovo ThinkPad Helix Battery Replacement: шаг 2, изображение 2 из 3 Lenovo ThinkPad Helix Battery Replacement: шаг 2, изображение 3 из 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: шаг 3, изображение 1 из 1
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: шаг 4, изображение 1 из 1
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: шаг 5, изображение 1 из 2 Lenovo ThinkPad Helix Battery Replacement: шаг 5, изображение 2 из 2
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
Заключение
7 участников успешно повторили данное руководство.
Manuel Parra Rocha
Участник с: 08/26/19
494 Репутация
Автор 2 руководств
Команда
Gateway, Team S1-G6, Saknee Fall 2019 Участник Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 членов
Автор 3 руководств
Один комментарий
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 22
За последние 30 дней: 85
За всё время: 6,846
