Введение
This guide will give you the instructions needed to replace the laptop's cooling fan. The fan is needed to keep the laptop from overheating.
Выберете то, что вам нужно
Remove the 8 screws holding down the back panel using the Phillips screw driver #000.
Remove the 9 wafer-head screws, size M2x4mm, using the Phillips screwdriver #000.
Почти готово!
Заключение
