Lenovo ThinkPad T420s RAM Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T420s RAM Replacement, RAM: шаг 1, изображение 1 из 2 Lenovo ThinkPad T420s RAM Replacement, RAM: шаг 1, изображение 2 из 2
    • Flip over the laptop so the bottom is facing up.
    • Unscrew the two black 5mm screws on the memory panel with your Phillips #0 screwdriver.
    • These screws are attached to the panel and are not made to be removed.
  2. Lenovo ThinkPad T420s RAM Replacement: шаг 2, изображение 1 из 1
    • Push the metal clips away from the RAM.
    • Slide out and lift the RAM.
    • When replacing ram be sure to align correctly and remove carefully to avoid damage.
Заключение
6 участников успешно повторили данное руководство.
Tristan Broughton
Участник с: 04/14/15
671 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 6-13, Maness Spring 2015 Участник Cal Poly, Team 6-13, Maness Spring 2015
CPSU-MANESS-S15S6G13
4 членов
Автор 5 руководств
4 Комментариев
This is only part of the game. There is another slot located under the keyboard. Lenovo wants this slot to be used first when only one of the two are needed.
cosy69 - Ответить
It may require a BIOS update (or not) but the Lenovo T420s supports 16GB of RAM.
Bryan Montford - Ответить
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - Ответить
@Keith Cloward
This is a guide for the T420S, not the T420.
Eric Van de Kerckhove - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 43
За всё время: 9,474
