Введение
This guide will show you how to locate and replace the Lenovo T431s charging port. The charging port is crucial for charging your computer’s battery. If you are experiencing charging problems, loose port, or unresponsiveness, then you may need to replace your charging port.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
Remove the charging port assembly.
2 участников успешно повторили данное руководство.
