Введение
Display not working and needs replacing? Want to upgrade to a higher quality display? This guide will show you how to remove your T440p display to achieve just that.
Removing the display isn’t that difficult and doesn’t take too long. You’ll just need a plastic opening tool, a Phillips #0 screwdriver, and just 10 minutes of your time.
Выберете то, что вам нужно
Slide each of the battery latches away from each other into the unlocked location.
Carefully pry the display bezels away from the display using the plastic opening tool.
Locate the latch attached to the display cable.
Grab the latch and flip it over so that it is facing away from you.
5 участников успешно повторили данное руководство.
2 Комментариев
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
