Lenovo ThinkPad T460s Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Wi-Fi Card Replacement: шаг 2, изображение 1 из 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Wi-Fi Card Replacement: шаг 3, изображение 1 из 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Wi-Fi Card Replacement: шаг 4, изображение 1 из 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: шаг 4, изображение 2 из 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement: шаг 4, изображение 3 из 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: шаг 5, изображение 1 из 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: шаг 5, изображение 2 из 3 Lenovo ThinkPad T460s Wi-Fi Card Replacement, Wi-Fi Card: шаг 5, изображение 3 из 3
    • Disconnect the gray and black cables from the Wi-Fi card.
    • Remove the 3mm Phillips #1 screw on the chip.
    • Remove the Wi-Fi card from the device.
Заключение
2 участников успешно повторили данное руководство.
kewei xia
Участник с: 10/01/19
457 Репутация
Автор 2 руководств
Команда
2 Комментариев
which replacement modules would you recommend? I am looking for alternatives to the 8260 that seems to be flawed.
albert einstein - Ответить
I have now replaced my Wifi-Card and just wanted to point that you instructions diverge from the official ones suggested by Lenovo. This manual simply recommends to deactivate the internal batteries through a bios option - which seems easier than the instructions laid out here.
still, cheers for your guide.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 45
За всё время: 3,106
