Введение
This guide will show you how to replace the SSD on your Lenovo Thinkpad T480 laptop. Backup your data before replacing if possible.
Выберете то, что вам нужно
Push Clip 1 to the side. While holding Clip 2 to the side, push the battery out of the laptop.
Pry up on the casing using a spudger or a flat-head screwdriver and remove the back.
Pry up on the little metal bar on the connector and pull the connector out of its socket.
Pry up on the left side of the SSD casing. Pull the casing to the left, and remove.
Еще один человек закончил это руководство.
