Lenovo ThinkPad T490s Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: шаг 1, изображение 1 из 2 Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: шаг 1, изображение 2 из 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Replacement, Release the clips: шаг 2, изображение 1 из 2 Lenovo ThinkPad T490s Battery Replacement, Release the clips: шаг 2, изображение 2 из 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Replacement: шаг 3, изображение 1 из 2 Lenovo ThinkPad T490s Battery Replacement: шаг 3, изображение 2 из 2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: шаг 5, изображение 1 из 2 Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: шаг 5, изображение 2 из 2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: шаг 6, изображение 1 из 2 Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: шаг 6, изображение 2 из 2
    • Use a Phillips #0 screwdriver to remove the five 5.2 mm-long screws securing the battery.
  7. Lenovo ThinkPad T490s Battery Replacement, Remove the battery: шаг 7, изображение 1 из 3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: шаг 7, изображение 2 из 3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: шаг 7, изображение 3 из 3
    • Lift the battery straight out of its recess and remove it.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Участник с: 01/16/22
93 511 Репутация
Автор 438 руководств
Команда
iFixit Участник iFixit
Community
136 членов
Автор 15 118 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 65
За последние 30 дней: 312
За всё время: 2,037
