Введение
When a blue screen occurs on your Lenovo ThinkPad T495, an error code will appear somewhere on the screen, as well as a scannable QR code which can be used to diagnose what is wrong with your device. In the case of this guide, the lack of memory or faulty memory will be covered, and the stick of RAM will be replaced.
Выберете то, что вам нужно
Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
Lift off the baseplate.
Use your fingers to gently pull the two arms on each side horizontally until the RAM springs up.
Grip the RAM between your fingers and pull it gently until it releases from the port.
