Введение
If the internal battery for your Lenovo Thinkpad T560 has gone bad and needs to be replaced, follow this guide. Note that the Lenovo Thinkpad T560 has two batteries: an internal battery and an external battery.
The most common reasons to why this component needs to be replaced are:
- The battery is failing to charge effectively
- The internal/external battery has gone bad
Before replacing the battery, make sure to power down the device and disconnect it from any external power sources.
Выберете то, что вам нужно
Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
Use the iFixit opening tool to pry the back panel off your T560.
Work your way around the perimeter of the device to undo the clips and detach the back panel.
Disconnect the battery connector from the motherboard by pulling it out of the port.
Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
Remove the battery.
