Введение
Do your stored files appear corrupted for no reason? Does your laptop have a slow boot time? Then this guide should help you either replace the hard disk drive (HDD) or solid-state drive (SSD) installed within your device. Keep in mind that this device does not support SSDs with M.2. slots.
Выберете то, что вам нужно
Flip the laptop to the bottom so the backplate is shown.
Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
Use a Phillips #00 screwdriver to unscrew the single 3 mm screw that secures the hard drive.
Lift up the bottom half of the hard drive at a 25 degree angle.
Simply pull out the hard drive.
Safely remove the plastic guard surrounding both the hard drive and ESD shielding.
Еще один человек закончил это руководство.
