Введение
If your programs began to slow down your laptop, or programs continue to hang under load, then this guide should help you replace the RAM/Memory stick within your laptop. This guide is also helpful in the case that you need to upgrade your laptop's RAM sticks.
Выберете то, что вам нужно
Flip your laptop to the bottom so that the backplate is shown.
Unscrew the captive screws on the backplate with a Phillips #0 screwdriver.
Locate the two latches that hold the RAM stick into the laptop, and push them away from the stick.
After pushing on the latches, the RAM stick should lift up at an angle.
Safely push forward the RAM stick away from the slot, and remove the stick entirely.
