Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 2, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 2, изображение 2 из 2
    • Use a plastic opening tool or your fingers to pry off the cover.
    Use the plastic tool as seen in the picture (pry at the hinge side) as on the nearside of the laptop are some plastic scoop brackets, so prying at the front will be a lost cause and may cause damage.
    Casey - Ответить
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: шаг 3, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: шаг 3, изображение 2 из 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 4, изображение 1 из 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 5, изображение 1 из 1
    • Remove the battery by pulling it directly towards you.
    Before installing the new battery, the attached cables connecting it to the board need to be bent or kinked in a similar manner to how the old battery’s cables were. I looked at the old battery’s cables for an idea of how to bend the new cables.
    Also, I saw how the old battery had some very thin foam attached to the battery (as seen in the photos), and that the replacement iFixit battery didn’t have such foam. I couldn’t figure out a way to remove the foam from the old battery without destroying it, so I went ahead and installed the new battery without it.
    Nhan Nguyen - Ответить
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: шаг 6, изображение 1 из 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 7, изображение 1 из 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 8, изображение 1 из 1
    • Remove the fan by lifting it directly up.
    Clean off using a cotton bud the old Thermal paste from the fan heatsink. When replacing the fan onto the new motherboard, you will need to apply a thin layer of Thermal Paste, which may or may not have come with the replacement motherboard. Apply the paste onto both metal plates on the motherboard.
    Brian Miller - Ответить
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: шаг 9, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: шаг 9, изображение 2 из 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 10, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 10, изображение 2 из 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 11, изображение 1 из 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 12, изображение 1 из 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
    Use a pin to remove the SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 13, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 13, изображение 2 из 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 14, изображение 1 из 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 15, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 15, изображение 2 из 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 16, изображение 1 из 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: шаг 16, изображение 2 из 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
    Need to also remove all 5 Motherboard Screws before lifting it off.
    On the right hand side in the middle is a plastic-pin that prevents the board pulling left. You have to lift the board a bit more than you want to. Or fiddle on the right side, to lift it up a bit there too.
    Thomas - Ответить
Заключение
4 участников успешно повторили данное руководство.
Eevee Murdock
Участник с: 01/23/20
1 086 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S18-G4, White Winter 2020 Участник Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 членов
Автор 7 руководств
2 Комментариев
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - Ответить
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 70
За всё время: 3,688
