Введение
This guide shows how to replace the battery on the Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710.
Users should have their device powered off for this.
Выберете то, что вам нужно
Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
Remove the back cover using the opening tool, leaving the laptop back exposed.
Use the opening tool to pry the edge and work your way around the perimeter.
Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
3 участников успешно повторили данное руководство.
