Введение
Follow this guide if you wish to replace the CMOS battery on your Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710. This will be a fairly simple guide and should be quick for most users. Having a proper a CMOS battery allows for the laptop to be used without being connected to a power source.
The device should be powered off and disconnected from the charger when being worked on.
Выберете то, что вам нужно
Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
Remove the back cover using the opening tool, leaving the laptop back exposed.
Use the opening tool to pry the edge and work your way around the perimeter.
Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
Еще один человек закончил это руководство.
