Введение
This guide will show users how to replace their heat sink and fan on the Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710. The fan and heat sink work together to keep the laptop cool. Replacing this could help with overheating issues the user is experiencing. The device should be powered off while working on the device. This guide can take some time to complete so be sure to keep that in mind when working on the device.
Выберете то, что вам нужно
Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
Remove the back cover using the opening tool, leaving the laptop back exposed.
Use the opening tool to pry the edge and work your way around the perimeter.
Use the Phillips #1 screwdriver to remove all five 1 mm screws holding the fan and heat sink down.
Еще один человек закончил это руководство.
