Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: шаг 1, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 2, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 2, изображение 2 из 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: шаг 3, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: шаг 3, изображение 2 из 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 4, изображение 1 из 1
    • Take out the battery by lifting it from the bottom edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: шаг 5, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: шаг 5, изображение 2 из 2
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 6, изображение 1 из 1
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 7, изображение 1 из 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: шаг 7, изображение 2 из 2
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
Заключение
Еще один человек закончил это руководство.
Michael Megna
Участник с: 01/23/20
1 277 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S19-G4, White Winter 2020 Участник Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 членов
Автор 22 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 1,376
